Old 27-Jan-2017, 9:13 PM   #2
Hello, Welkin
In the basement with a building in the signal path is a very poor antenna location, but your local signals are very strong. I have good reception with a GE Attic Antenna indoors on the ground floor. The antenna is inexpensive, but you have to assemble it yourself.
video
https://www.youtube.com/watch?v=1qYucg3JXzA
If you don't want to assemble an antenna, I suggest an Antennas Direct C2V.
Also, what would be the best outdoor omni-directional outdoor antenna just in case I can mount an antenna outside?
You do not need and should not use an Omni; your best signals are coming from the SSE.
Antennas Direct C2V, DB2e, RCA ANT751
