In a nutshell then ... find the happy spot.
So, for optimal antenna placement, instead of walking the antenna around the property, searching for the "hot spot", Is there a meter of some sort that one can use to locate the best signal(s) available at a particular site?
If not, then what method is best, for positioning the antenna? From the info you just provided, my best reception may be down on the ground somewhere.
Again, thanks for the help. This is working out way better than expected.
