I have a ton of co-channel interference. How much of a concern is this?
It's only a concern if, after installing the antenna(s), the differential is not adequate. The simulation can give you a heads-up to look closer at specific pairings to see if an issue is likely to come up. It just takes a bit of math. A lot of the warnings are not going to be an issue due to actual signal powers and the direction the signals come from vs the directivity of the receiving antenna(s).
