From the sounds of the last post, band conditions may be causing some of the trouble recently.
However, since you are only interested in wbz, wcvb, whdh,wfxt, wlvi, and CH 60, the stacker's vhf elements are merely bringing in high vhf interference and overload producing signals.
26 ft of rg6 has no detectable loss so no need for preamp
To first split point.
You may be able to re purpose the preamp to boost the signal to the 60ft coax run
Again, TV tuners are easily desensed and driven into overload by large disparity between TV signals and interference from the literally hundreds of sources
