Old 19-Jan-2017, 1:52 PM   #4
johnodon
Thx ADT.
I plan on going up to the attic later today and removing the pre-amp from the path and connecting the main lead directly to the DB4E. I'll report back.
Question: does the fact that I actually gain signal (on UHF) when I take power away from the pre-amp indicate that it is hurting rather than helping when powered (overload)? Or could that be more a side effect of a faulty pre-amp if that turns out to be the case?
Dist. Amp is this: http://www.solidsignal.com/pview.asp?p=pctma28p
On a side note, if I pull power from the dist. amp, I lose signal altogether. I don't know if this by design or if it indicates that the power is really helping that much. Does that amp require power to operate (no passive operation)?
John
johnodon is offline   Reply With Quote
