Good info from Jake v and ground ur mast.
Also, with the recent weather, condensation could form inside outdoor connections that aren't sealed well.
The slightest amount of condensation in a connector can cause signal loss on frequencies and over time will cause corrosion and dielectric contamination.
I like to use coax seal to make the connections air tight
