Rabbit73-
As one of my options, I am considering something like the simple approach you mentioned. It would be nice to avoid the extra moving parts and complexity of a rotor system.
You mentioned...
"...a preamp which would be overloaded by your very strong local channels."
If you don't mind, please, help me understand this phenomenon a bit more. Do you mean that if you use a preamp, that the preamp'ed signal can become overloaded by the strong local signals? What is the result? Does it just degrade the local signals? Does it block the distant signals? Is there a work around?
