Old 14-Jan-2017, 4:22 AM   #1
xyzer
Tree mount Antenna + more
I am in a quite rural area south of Bend Oregon and on a quest to receive as many OTA signals out there. My report is at 30 feet to reflect the way my current test configuration is mounted. 200 feet coax.
http://www.tvfool.com/?option=com_wr...e6a43b7ca3bf50
In the late summer early fall I started testing with a cheap 150mile antenna to see if anything was out there.
It encouraged me to invest in a DB8E. The scan brought in more channels.
I installed a Juice preamp.That gave me a couple more except our PB broadcasting station. It is down in the real channel 11 VHF area. I installed a VHF kit and got it.
I tried to hook up a TV in another room and it all went to 1 channel. I installed a Channel Master CM3414-4 way splitter. and that works great.
All of the gains in new channels always had a new few that would vary on usability.
I know elevation is part of my problem now. I am surrounded with Ponderosa trees with a few holes in the direction of the towers. I have the opportunity to have my way with a 65' boom bucket for a week or so. My intention was to mount the antenna to a tree at about 60'. I know there are probably pro and cons on this but I don't have many choices.
While I have the opportunity to make a more permanent home for the antenna this summer I have no problem spending a couple of satellite bills or more for a good VHF and maybe separate UHF antenna and if necessary a rotor. I wont be able to adjust it after it is installed.
Any suggestions are welcome.
Dave
xyzer is offline   Reply With Quote
