Old 29-Jan-2011, 12:00 AM   #2
John Candle
Tv Antennas and Reception
If the building is not wrapped with metal such as but not limited to metal siding or stucko with stucko WIRE. If the building does not have a metal roof. If the walls are not made of poured concrete. If the building does not have foil backed insulation. If the Tv is not in the basement. Then a SIMPLE NON Amplified indoor Tv antenna will get you most of the channels in green. In any event try a simple indoor Tv antenna FIRST before installing a outdoor roof top Tv antenna http://forum.tvfool.com/showthread.php?t=233 . . . If you go to a roof top Tv antenna then ANT751 or similar small roof antenna will power 1 or 2 Tv's. . Read and understand this about Real Digital Tv Channels and Virtual Digital Tv Channels and Analog Tv Channels. http://forum.tvfool.com/showthread.php?t=695 . Here is how to aim Tv antennas http://www.kyes.com/antenna/poinying/pointing.html . . Indoor or roof top Tv antenna point at about 330 degree magnetic compass.
