Old 11-Jan-2017, 5:54 PM   #7
For channel 13? No, you need a LOT bigger high-VHF antenna to have a shot at that station.
You could try adding a ClearStream 5 (requires U/V combiner) which is roughly ofcomparable performance to a 5-6 element Yagi but in a compact form factor. It would be right on the edge according to the available math. The next step up would be to go with a more conventional high-VHF Yagi of which there are few options. Most notable option appears to be one that MCM imports from China. I haven't tested it but it is available and is more directional and is higher gain than a C5. It's also a lot larger.
