Thanks, Jake. The rep I chatted with at Antennas Direct suggested a DB-8e for the additional 3 dB, with their VHF add-on, and an amp. The VHF add-on seemed like it might not be quite enough. Others have suggested a Winegard 7698 if I can fit it in the space (probably can) or if I go to the roof.
I'm liking your two-step approach that starts with the weakest channel. I could get the amp and compare with/without (risk of nearby channels saturating, right?). Thoughts on the DB-8e being worth it?
Thanks again!
