What antenna do you have? Omni-directional antennas do not usually have the reach of a directional antenna. Your stations aren't that far away but I am unsure of the terrain / foliage around your location, I would guess that something is blocking the signal since WHDH is showing as 2 Edge.
Even though it's omni-directional, I would still try rotating it to see if you can improve your reception or try placing it in another location in your attic or possibly on the roof.
You can also try another antenna, if all of your stations are in the same general direction, a directional antenna would work best. It looks like you're near 2 media markets so it doesn't seem like that's the case. However, the channels listed in green still may work fine even if you pointed a directional antenna at about 155 degrees because all of those stations are fairly strong.
What are the call letters of 5.1?
