Old 28-Jan-2011, 11:28 PM   #3
The Winegard FV-HD30 should do well for you if it is not blocked by the roof as you aim it toward the NW. Even if it's blocked, try it where it's most convenient for you to mount it first.
The Clear Stream is a good antenna, but not designed to cover all the channels available to you.
