I would call and complain that the package arrived damaged and that the antenna does not pick up uhf then insist on an RMA for a free return. Regardless, the 30-2476 is the best VHF high antenna available at this time. Using two antennas lets you point each optimally. If you can pickup WRGB on 39, there is no need to worry about vhf low.
