Old 29-Dec-2016, 5:22 AM   #33
eggman531916
Why not use a wall mount? That's what I used for my DBGH with 3' wide screen reflector. Hasn't moved yet and it's been up there for a while now. I had to buy a set that mounted it 18" off of the wall to get around my eaves, but it's working quite well. If it's done with a wall mount, would he then be able to run the mast all the way to the ground if its moved over closer to the chimney? Or would it still be too close to the electrical meter?
eggman531916 is offline   Reply With Quote
