27-Dec-2016, 3:05 AM
#32
Antenna Enthusiast
Originally Posted by wado66
Got to checking my eaves and I do not have adequate support. Just 1X boards.
Having to rethink the whole process.
I think a simple Tripod either 3', 5' or 10' is your answer. Your roof is pretty high, so a 5' Tripod with a 10' mast would not be too gaudy. I think you could go 10 feet from the roof peak with out guy wires as long as you have a good solid tripod. I think that would get you at least 30' AGL.
Solid signal sells a 5' Skywalker Heavy Duty Tripod with dual internal braces at just less than $30! It has a fairly wide stance. I bought one just to have it, I thought it was such a great deal.
Blows away more expensive tripods and it much more stronger than a 3' tripod. here's the 5' tripod I'm talking about:
http://www.solidsignal.com/pview.asp?p=sky6046
You can add a rotator, but keep the upper mast shorter, to reduce wind load on the whole assembly. Guy wires are awesome, but can be a pain to seal holes and line up the eye hooks with rafters.
