Old 25-Dec-2016, 7:20 PM   #11
Next Day: checked today and as it's daytime with no light display, and no reception from any of the towers whatsoever.
They must be home and not at work.
What channel do you use for the news?
If the interference is coming through the power line (conducted interference), then another circuit for the TV might help. A power strip with an RF filter might help.
If the interference is coming through the air (radiated interference), then grounding the coax shield with a grounding block might help.
Are your AC outlets 2-wire or 3-wire with a grounding pin?
