Old 25-Dec-2016, 7:40 PM   #9
One of the tools that I use to hunt for interference is a battery operated portable radio that tunes the AM broadcast band. If the interference is strong enough to affect TV reception, it will often be heard on AM. An FM portable doesn't work as well. Tune to a clear frequency at the low 540 end and listen; then try the 1600 high end. The built-in antenna acts like a direction finder. An AM radio in the car or a portable radio that tunes the Aircraft Band, which is also AM, can also be used.
If you did this:
Default Thread Subscription Mode:
Instant email Notification
Save Changes (at bottom of page)
and you checked to be sure that you entered your correct email address
and you checked your other email folders besides Inbox like:
Trash
Junk Mail
then contact tvfool Admin
http://www.tvfool.com/
click on Contact Us
If you already did a Log In, the first two lines of the Contact Us form will have your Username and email address entered.
