Use EITHER the CM3414 or the 7778 with a passive four-port splitter. Do NOT use both the preamp and the distribution amp.
The trees blowing in the wind are your major concern, not the amplifiers. See if the trees are avoidable. If not, you're very limited on what you can do with hardware to "fix" the tree problem.
