The best was to distribute signals to TVs is by using taps like cable companies use
With taps, all TVs can get the same signal levels from the first TV to the last
Splitters lose 3.5db per port so by the time you add multiple splitters and coax runs, the first TV is in overload while the last TV is into the noise
If you must use splitters, amplified splitters become your only affordable option
