Old 18-Dec-2016, 5:48 PM   #12
JTl
Yes, but I can't give you a guarantee because I'm not there with you. I'm counting on you to do the work that I would do if I were there.
Yes, you must put it at the beginning of the first 50' run. It makes a difference of about 3 dB. You can put it any place you want, but where I suggested will give the best results.
Your 3-way splitters have more loss; use only 2-way splitters. Any ordinary passive 2-way splitters should be OK.
http://www.solidsignal.com/pview.asp?p=PV22-103
https://www.walmart.com/ip/GE-33526-...itter/52162882
http://www.homedepot.com/p/Ideal-2-4-GHz-2-Way-
Splitter-85-332/202276264
Maybe I am misunderstanding but I thought I could also put it at the end of the 50' run using an adapter.
JTl is offline   Reply With Quote
