Old 18-Dec-2016, 3:25 PM   #11
Do you think there is good chance this will solve my problem?
Yes, but I can't give you a guarantee because I'm not there with you. I'm counting on you to do the work that I would do if I were there.
Does it make a big difference if I put the CM3410 at the beginning vs the end of the long run in terms of signal strength.
Yes, you must put it at the beginning of the first 50' run. It makes a difference of about 3 dB. You can put it any place you want, but where I suggested will give the best results.
Like i said I have a couple of mis-matched old splitters, can you recommend ones for this project.
Your 3-way splitters have more loss; use only 2-way splitters. Any ordinary 2-way splitters should be OK.
http://www.solidsignal.com/pview.asp?p=PV22-103
https://www.walmart.com/ip/GE-33526-...itter/52162882
http://www.homedepot.com/p/Ideal-2-4...-332/202276264
