UHF antennas will receive 2 thru 6 and 7 thru 13 when the antenna is close to transmitters and the signals are strong as in your case. It helps reception if a Tv antenna is placed at a window that faces the Tv transmitters , and if the window does not have real metal window screen. These old Row Houses had or may still have real metal window screens. In an attempt to improve/update the look of these old Row Houses some have been wrapped with stucko WIRE and had stucko put on. This does not improve the look of the house it makes it look worse and the stucko WIRE blocks Tv signals.
