Old 18-Dec-2016, 3:55 PM   #10
JTl
Yes, if it is this one:
Which PCT model are you talking about? PCT bought out Channel Master, so it is the same company, but they make several different models that are similar.
Do you think there is good chance this will solve my problem?
Does it make a big difference if I put the CM3410 at the beginning vs the end of the long run in terms of signal strength.
Like i said I have a couple of mis-matched old splitters, can you recommend ones for this project. Thanks for all of your help.
JTl is offline   Reply With Quote
