Old 18-Dec-2016, 12:06 AM   #6
Code:
             20' > TV
C2 > 5' > SPLITTER #1              50' > TV
              CM3410 > 50' > SPLITTER #2
                |                  |       20' > TV
              POWER                |      /
                                   SPLITTER #3
                                           20' > TV
All splitters are 2-WAY
IF AC POWER IS NOT AVAILABLE AT THE 3410, ADD A PCT-MPI-1G
POWER INSERTER AT THE BOTTOM OF THE FIRST 50' COAX JUST
BEFORE THE SECOND SPLITTER.
If you have AC power at the first splitter, the DC power for the Channel Master 3410 goes in the upper left port. If you do not have AC power at the first splitter, then you must provide remote DC power for the 3410 through the first 50' run using a power inserter just before the second splitter.
I am suggesting the 3410 and 2-way splitters instead of the 3414 so that you can send more signal to the longer runs for better balance.
The PCT-MA2-M is the same as the CM3410.
Last edited by rabbit73; 18-Dec-2016 at 5:59 PM. Reason: Inserted 3410 images in diagrams
