Old 18-Dec-2016, 12:36 AM   #5
JTl
Maybe, don't have enough information.
What direction is the C2V aimed and what specific station or station is involved?
The cumulative insertion loss for a 2 port splitter, a 3 port splitter, and 90' of RG6 is about 16 dB. Unless you're dealing with weaker stations or the antenna isn't aimed for that station, an amp shouldn't be needed. We do need additional information to advise you.
Maybe I don't have the correct splitters, they were just ones I had laying around from ancient times. When I hooked up the long run to another 20' run without using the second (3 way splitter) I got all but the station at 118 degrees, not that I even care about it. The stations that I want are ABC, NBC, FOX, CBS and PBS. They are all very close and seems to me if I can get any of them I should get all of them.
JTl is offline   Reply With Quote
