Old 18-Dec-2016, 12:10 AM   #4
JTl
Yes
Where is the antenna located?
How long is the coax from the antenna to the splitter?
Are the channels from the SE what you are interested in?
The antenna is located on SE side of the house. Pretty much a straight shot. The first splitter is only 5' and then one leg goes another 20', the other side goes 50' and I need to split the long run again 3 ways, two 20' runs and another 50'. The first split (short one) is perfect reception. Not so on the others.
I only care about the channels from the SE. Thanks for your response.
JTl is offline   Reply With Quote
