Old 16-Dec-2016, 11:37 PM   #5
Thank you for the report. It is only resolved to block level. Small changes in location can often make a big difference in the report. Is it possible for you to do another report with exact address or coordinates? If I had a choice, I would want to look at a satellite view to see the green signal lines.
I see the problem with the hill when I click on a callsign in your report. You have a difficult location and I'm trying to figure out if any improvement is possible.
Where are your antennas located?
What is your UHF antenna?
Are you using a preamp?
Do you have a rotator?
Are there any trees or buildings in the signal path?
What equipment are you using for reception?
