15-Dec-2016, 1:10 PM
#6
Antenna Enthusiast
Mounting tab
Originally Posted by WIRELESS ENGINEER
Did a little more research and saw someone had a similar issue
They dealer he bought it from said if they are using thrust bearings, they needed to break off the tab on the rotor body just above the u clamps
He did that and it would turn 360 degrees again
Thanks for your continued interest in my rotator fiasco.
Early on I knew to remove the tab on my CM 9521, it is absolutely necessary for my type of install.
The tab is of course if you are mounting to the top of your main mast. It makes it easy to leave the rotator loose while positioning it. It also may be responsible for weight bearing, but once the clamps are tight, I don't think it will make a difference.
I actually checked for binding in my support bearings while my rotator was slid down . I could easily spin the mast by hand.
I read through the CM9521A instructions and saw nothing about weight limits, although I agree there has to be a weight limit.
Still looking for a deal on a better rotator.
Thanks, Bob
