I'd especially appreciate suggestions for removing the issue
I'd recommend simply 1) moving the antenna so it's not right on the metal gutter and 2) move it so it isn't staring point blank into a tree. Both are commonly encountered but less obvious installation errors.
Proximity to large metal surface causes interference with anticipated antenna patterns and can, if the proximity is just wrong, act as a trap for a specific frequency.
Trees can cause unpredictable results and can cause dead spots for specific frequencies for a very specific location in the spatial environment behind the tree. With UHF wavelengths, moving the antenna by as little as 6" can move a receiving antenna either into or out of these highly localized dead zones. FWIW, I'm going to blame it on the tree until any other factor surfaces.
You do not need a different antenna, you just need to use the one you have more effectively.
