Old 12-Dec-2016, 4:45 PM   #11
The XYL won't allow a tower...so can't experiment that much.
You must be a ham.
My wife tolerates my antenna experiments because she wanted a battery operated TV for use during a power failure. She even bought a signal level meter for me.
An indoor antenna worked for an analog TV near a window, but it doesn't work for digital TV because the insulation in the outer walls has an aluminum foil vapor barrier. We are living in a Faraday Cage. I had to set up an outdoor antenna on the porch.
73,
W4...
ex W2...
ex DL4..
