Old 8-Dec-2016, 2:24 PM   #1
seeyabarney
Preamplifier Reset
I just put up a Televes UHF antenna and stacked it with a Televes VHF underneath. I pointed them both in the same direction and immediately got 20+ channels. Later that evening the channels were broken up and reception was bad on half of them. I replaced the cables and the same thing happened as far as great reception for a few hours and then back to spotty reception a few hours later. Out of frustration I went down to the basement and unplugged the preamp and plugged it back in again. Now I am getting my 20+ channels again. It this a common occurrence and what else would have caused this to happen if this little trick doesn't work again? Thank you.
seeyabarney is offline   Reply With Quote
