Old 7-Dec-2016, 9:25 PM   #1
mikebuild
Reception better from my RV antenna ... ?
Hey all,
Newb's got a question ...
I just built a DB4 and mounted up on the roof. It sits about +40' off the ground, my RV's Wingard (model ?) sits about 12' off the ground and about 50' away from my new DB4. The RV will find 17 channels and the DB4 will only find 8 channels. I have an amp on the DB4 and the Wingard supposedly has an amp built in. How can the Wingard be getting better reception than the DB4 that's sitting so much higher. Is the RV just sitting in a hot spot? When the snow melts, I'm going to move the DB4 down by the RV and see what's what.
Which antenna model/style would you try here ( at my location)?
http://www.tvfool.com/?option=com_wr...dfaf44e4451727
Lots of people online claiming their home made antenna's perform better than the store bought versions, what's been your experience?
Thanks, Mike.
mikebuild is offline   Reply With Quote
