Old 6-Dec-2016, 2:52 PM   #6
wizwor
The antenna he already has is too directional to be aimed due south and be expected to pick up the stations 75° off to the east.
If he's pointed the antenna directly in that direction and it still doesn't work on those two stations, then he's got a problem that first must be diagnosed. That information hasn't been provided.
I recommended new antennas with wider beam widths. That's what he needs and the cost will be about the same as a rotor with less maintenance.
The C5 is practically omnidirectional...
https://www.antennasdirect.com/cmss_...with%20uhf.pdf
The DB8e's panels can be articulates to receive from both broadcast areas concurrently.
wizwor is offline   Reply With Quote
