- Is there a way on TV Fool or otherwise for me to determine transmitter height that I'm missing?
No. While that data is used by the simulator, it's not present to the user as separate data. I pull that info from the FCC or IC's licensing database or from rabbitears.info (which pulls from the FCC database).
That is why I was hoping there may be a way to do the same with RF 13 but no luck.
You really need a VHF-capable antenna to pick up that weak of a channel 13 signal.
- With the stacking option, would that consist only of adding another 91XG?
It can be done with any two identical same-band antennas. The antenna you referenced doesn't count.
I was not aware how to decipher the Eff ERP so thank you for that.
That has to do with how the transmitting antenna's pattern and your angle relative to it (if the antenna is directional).
