Old 2-Dec-2016, 1:23 AM   #2
Thank you for the additional information about your location. When I look at the satellite photos, I see your location at the end of an access road off the main road.
The satellite image from the tvfool interactive map browser, using Google maps, was done in the winter when the leaves were off the trees. The image from Bing maps, if I have the correct location, shows a lot of trees that might block your signals. You will need to find a location for your antenna that avoids the trees as much as possible.
A high gain UHF antenna aimed at about 14 degrees magnetic and a preamp should work. My only concern is about NBC. If KTAL is too weak, you will need a rotator or a separate antenna, and single channel injector for KETK.
CW is also in a different direction.
Antenna: Antennas Direct DB8e with both panels aimed in same direction, or 91XG, or Solid Signal HDB91X.
Preamp: Antennas Direct Juice or Channel Master 7778.
