Old 1-Dec-2016, 4:54 PM   #1
Thirstyrock
Occasional vibrating blocks on channels 33-35
(Phoenix, AZ. 85053) I have an Antennas Direct DB8 installed outside on a 25' pole. Quad shielded RG-6 Cable also. The only channels I seem to have problems with is the channels in the 33-35 range where I occasionally get giggling blocks that appear than diasappear. There is nothing blocking the line of sight to towers and cable as well as antenna mast are grounded. I did notice I get channels above the 51 group. Like 61.1, 61.2 etc. which I thought was were not to existant anymore which also seem the shows are broadcasting on lower channels also. I have rotated the antenna several times and no luck on those channels in the 33/35 range. Any ideas please would be greatly appreciated.
Thirstyrock is offline   Reply With Quote
