You are welcome. I'm glad that I helped you understand how important it is to have an HD signal with a big screen TV.
You can also see the difference compression can make if you compare 480i QVC and HSN on ION OTA with the better 480i on PBS Create OTA.
I included the left side of the TV frame (except CBS; image too wide) to show that all images were about the same magnification; 40mm on my 15 inch laptop computer at 100%.
