Thread: Help in S.E.Va.
Old 26-Nov-2016, 11:35 PM   #24
Thank you for doing some more tests to eliminate some possibilities.
Tried another Tv- 32" Panasonic and that also was the same.
Also did the double rescan on the 32" TV
I want to be sure that I understand the results of your tests. You seem to say that the Sony AND the Panasonic both can get 49.1 but not QVC (49.5) and HSN (49.6).
They don't come in good at all.
Does that mean there is no signal at all for 49.5 and 49.6 or does that mean there is a signal, but it is poor? Poor video quality or poor signal strength with pixilation and picture freeze?
If you mean that there is a signal for 49.5 and 49.6, but it doesn't look as good, then it could be because of the difference in video signal quality that is transmitted. 49.1 is transmitted in 720p video, but 49.5 and 49.6 are transmitted in 480i which is not as sharp, especially on a 65" screen.
http://www.rabbitears.info/market.ph...&callsign=wpxv
CBS broadcasts the best video quality, 1080i
http://www.rabbitears.info/market.ph...&callsign=wtkr
