Thread: Help in S.E.Va.
Old 20-Nov-2016, 8:01 PM   #6
I can get GE attic antenna if it will be better
I can't guarantee that it will be better because I'm not 100% certain yet what the problem is. Let's try some attenuation first with the antenna you have.
This is my friend's report; your signals are 10 dB stronger.
http://www.tvfool.com/?option=com_wr...dfafa556f19277
This is the attenuator I used when testing his antenna. I was able to insert the full 20 dB attenuation for his strongest signals without them dropping out. CH 13 was a little weaker because the GE antenna has less gain for VHF-High signals.
Also here
https://www.walmart.com/ip/Antennas-...uator/43160862
I bought mine here:
http://www.solidsignal.com/pview.asp?p=att-1
The knob on the attenuator works like a volume control with multiple turns. Turn it clockwise to make the signal stronger (less attenuation).
The GE 34792 is on sale at Walmart for $26.47 but requires some assembly. There is a video for that.
https://www.youtube.com/watch?v=1qYucg3JXzA
