Thread: Help in S.E.Va.
Old 20-Nov-2016, 8:58 PM   #5
WPXV is 258 degrees magnetic by compass.
If you get ION OK, then you should be getting QVC and HSN OK because they are all on the same channel. Try slightly different locations in the attic and an attenuator. Keep adding more attenuation to see what happens. Does your TV have a signal strength indicator?
