Old 28-Jan-2011, 6:18 AM   #3
Click on KGO on your report, for example, and you will see that the signal is blocked by terrain. And as John has pointed out, KRNV is also transmitting on channel 7, the difference in signal levels is less than 20 dB... The deck is stacked against you getting reliable reception from the SF stations.
How much are you willing to spend with no guaranty of reliable reception of the SF stations? Some folks are willing to spend a lot on their hobbies, so I don't want to assume I know what you're desire is.
