You may need more capture area on UHF and no yagi design will give you that and their gain tends to be on higher channels which you don't need
An 8 bay bowtie design may give you what you seek
And the channel master hd4228 is the best UHF antenna on the market as a direct result of massive capture area
If the 4228 won't pick it up then nothing will
