Old 10-Nov-2016, 8:27 PM   #31
That is supposed to be a good one, but coax surge protectors have a device connected between the center conductor and the shield that is known to degrade weak signals. I only use a grounding block which just grounds the shield and meets the requirement of the NEC for an ADU (Antenna Discharge Unit), especially if it is a "Listed" device.
Maybe ADTech will stop by and help you with the DB8e problem in post #26.
