Old 10-Nov-2016, 8:27 PM   #28
dustyz
How were you using the splitter? Did you add the splitter after the combiner but before the preamp input as an attenuator, or did you replace the DB8e combiner with a splitter in reverse as a combiner?
I replaced the DB8e combiner with the splitter in reverse. (A recommendation from Antenna's Direct to test the combiner.) I also placed it mid-line as a attenuator, which since it doesn't pass power, I realize was a mistake. I'll move it between the power inserter and tuner tonite.
Thanks for the link.
While I'm getting into it, can you think of anything else I should try? Antenna's Direct also said a local cell tower could be interfering with the CM-7777.
dustyz is offline   Reply With Quote
