Old 8-Nov-2016, 2:29 PM   #5
You will likely need to choose which direction to focus on. That's why rotors were invented decades ago.
It is unlikely that both a preamp and a distribution amp is needed. That arrangement is usually only needed in very very weak signal areas and where there is an very extensive signal distribution network with very long or a very large number of cable runs.
I would recommend no amplifier at all to start with, you may not need one. They can always be added later, if needed.
