Old 8-Nov-2016, 2:43 AM   #9
Fin745
KLRN PBS real channel 9, virtual channel 8.1
KCWX is listed as 8, but that is wrong; it's on ch 5
KQVE-LD Daystar real channel 13, virtual channel 46.1
KLRN is 9.1 and I'm getting 54% and SNR is 24.6
I'm not able to get 46.1 and KCWX is just as strong as WOAI
WOIA 4.1 I'm able to get with no issue Signal is 47% with 31.1 SNR
KENS is 5.1 and the Signal strength is 53% with 28.1 SNR
My UHF channels are 29.1 KABB and it's Signal strength is 56% with 28.1 SNR
KWEX-DT Signal strength is 50% with 29.4 SNR
KVDA is 60.1 and I'm getting 55% and 28.1 SNR
Thanks for the info I ordered a FM Band Rejection Filter from antennasdirect to see how that helps.
Edit:
Do you have a TV that you can try with the antenna instead of the TBS tuner card?
The Signal Diagnostics are from a TV and I see the same pixelation.
Fin745 is offline   Reply With Quote
