Old 5-Nov-2016, 3:48 PM   #3
aross6
Welcome, aross6:
Thank you for the report.
Where is the first 751 located?
Are there any trees or buildings in the signal path from 44 deg magnetic for the second 751 for the 9s?
WTOV is a lot weaker than WTRF. I think a preamp might help.
If that doesn't work, then the antenna outside and higher.
If that doesn't work. then a VHF-High antenna with more gain.
The 1st 751 is located on the front roof of the 1st story (above the front porch). The 2nd 751 I had hanging out the back window of a 2nd story bedroom. I'm sure there's probably a signal path issue as it's very hilly here and we live down in a valley. Like I was saying I had the 2nd antenna outside and probably at a height of about 20ft. So you're thinking that since it detected the channel signal was there but it was not strong enough to decode it that a pre-amp might work or would I be better off with a different antenna?
aross6 is offline   Reply With Quote
