Old 5-Nov-2016, 10:12 AM   #24
richardrosa
Thanks for the report. It sounds like it has been helpful for you. Which model did you get, the 3G Combo?
Yup. Got the 3G. Wish something like this was available YEARS ago.
I WILL give the antenna tilt a try. Now that I can see what is happening, it should instantly be obvious if that makes things better or worse. A new location may also be in order. All this to do in Spring (warmer weather).
BTW, What software did you use to generate those topography graphs?
Rich
richardrosa is offline   Reply With Quote
