Old 5-Nov-2016, 7:21 AM   #13
jacksonh18
Oh, Wow; I missed that and went by the noise Margin number in the report and the dBm number from rabbitears.info.
For some odd reason the FCC Longley-Rice K12LO Coverage Map supports the tvfool report; is it also wrong?
http://www.rabbitears.info/contour.p...14.03869444444
not sure what you mean. This is everything I can get by moving around my antenna.
250 degrees I get the following channels:
26.1 TBN
26.2 TCC
26.3 SBN
26.4 NRB TV
26.5 SOAC
26.6 SLSTV
26.7 WHT
26.8 DAYSTAR
34.1 ANT TV
34.2 RETRO
34.3 WALK
34.4 REVN
34.5 EBRU
34.6 GRIT
34.7 RT
34.8 YOUION
46.1 KUKLHD
46.2 KUKL
46.3 KUKLC
46.4 KUKLW
46.5 KUKLL
at 180 degrees I get:
23.1 KTMFABC
23.2 KTMFFOX
23.3 KTMFSWX
jacksonh18 is offline   Reply With Quote
